Monsoon FAQ
Found this online.
Monsoon FAQ - Camaro Zone
Hope this helps a few out there.
The Monsoon system consists of a head unit (radio with single CD player or cassette player), an external amplifier, and either eight or ten speakers (depending on vehicle model). There was also an optional external CD changer available that mounts in the cubby space on the left side of the t-top storage well in a coupe or the left rear of the trunk in a convertible. All Monsoon equipped F-bodies were pre-wired for the CD changer even if one wasn't installed. You'll find the changer harness taped to the hatch speaker harness under the trim on the left side. Even though the changer was made by Pioneer, it was made to GM specs and is not compatible with any aftermarket head unit (including those made by Pioneer).
The head unit is nothing special - it's just an ordinary 1.5 DIN Delco radio with a Monsoon label on it. In fact, some of the early Monsoon systems didn't even have the label on the head unit. Camaro HUs are black with black controls and blue/white illumination. Firebird HUs are dark gray with gray controls and red illumination. Both types are basically the same and are physically interchangeable although they had some different features - Camaros came with speed compensated volume whereas Firebirds have a graphic equalizer. Both are capable of using a power antenna but only the Firebirds came with one. None of the factory head units had MP3 capability, line-level (RCA) output, or auxiliary input other than for the factory CD changer (although there are adapters available).
The amp is a small eight-channel unit mounted on a bracket on the right quarter inner fenderwell (hatch area of a coupe, trunk of a convertible). It powers a mix of 2-ohm and 4-ohm speakers. The 97 and some early 98 models came with a 200 watt amp that was physically smaller than later models. The rest of 98 through 99 came with an amp that was rated at 200-watts RMS. For 2000 and later models, GM changed their advertising to rate the very same amp at 500-watts. Some say this is a peak rating while others just consider it an ILS (If Lightning Strikes) rating. GM also claimed an RMS rating of 240-watts for this amp but the original 200-watt rating given to the amp is probably more accurate. In any case, there is no point is trying to upgrade a 98 or 99 to the "more powerful" 500-watt amp of later years - it's exactly the same amp.
The speakers vary greatly between models. Firebird coupes have ten speaker elements mounted in six locations, Camaro coupes have eight speaker elements mounted in six locations, and convertibles of both lines have eight speaker elements mounted in four locations. The eight channel amp powers all speaker elements in the Camaro coupe and all convertibles. It powers all speakers except the tweeters in Firebird coupes.
Camaro coupes have component 6.5S 2-ohm mids and .75" 4-ohm tweeters mounted coaxially in the doors (they look like ordinary coax speakers but are actually wired as separate components), single voice coil 6.5S 2-ohm subs in the sail panels, and 4" 4-ohm full-range speakers in the hatch area. All eight elements are powered by the amp.
Convertibles have component 6.5S 2-ohm mids and .75" 4-ohm tweeters mounted coaxially in the doors. The schematics show 6.5S 2-ohm woofers and .75" 4-ohm tweeters mounted coaxially in the quarter panels beside the rear seats but inspection of the actual speakers has discovered both the woofers and tweeters are actually 4-ohm. All eight elements are powered by the amp.
^ Why would anyone buy a CD Changer in this day and age?! Just get a USA Spec unit, it plugs into the CD Changer port, and acts like one for your iPod/iPad, iPhone or AUX RCA jack connection!
This is the unit you need, I have them in both my Camaros:
USA SPEC: iPod Interfaces
Anyone have ideas on what one can do for the non-Monsoon models? I bought a new Bluetooth HD ready Sony XPLOD head unit and some new speakers, but it's still not up to snuff. Any ideas on good speaker placement for extra speakers?
