Headlight switch wiring help
Does anyone have the pin-out for the headlight/dimmer switch? I am installing a switch from a a 2000 trans am in my 67 Camaro. I think I have most of it figured out, but not quite sure about a couple of wires. Any information about what color wire does what function would be great. Thank you in advance for your help.
That will be a huge help. Would you happen to have the connector information for the dimmer for the dash/dome lights? If you don't mind me asking where did you find this? Thank you very much.
These schematics are all from the 2000 F-Body Service Manual. You can download a pdf copy here.
The IP Dimmer switch conn pinout is attached below.
Last edited by peterpar; Aug 1, 2019 at 02:43 PM. Reason: I added the IP circuit drawing to the conn drawing
