Drivers door window will not go.down
Old 05-10-2014 | 01:22 PM
FBodyjunkie's Avatar
Default Drivers door window will not go.down
Drivers door window doesnt do anything. Replaced the motor 4 years ago w a AutoZone motor. I hear the relay under the dash, but I hear nothing from the motor. I lubed the track, checked the fuse. Im guessing another motor? What's the regulator and how do I know if its bad? It was fine before it sat all winter.
Old 05-10-2014 | 02:07 PM
Can i just unbolt the motor w the window up? Do I just pull the gear mechanism off the motor gear and replace the motor then pop the track gear back on the motor?
Old 05-13-2014 | 08:38 PM
mp734's Avatar
check the switch. my button broke and i thought it was the motor.
Old 05-14-2014 | 02:21 PM
Mp, if you read my original post, I mention I already did that. Here's the update for thise who do read my posts, I bought a Delco original motor from.my dealer for less than the aftermarket auto part store knock off. I only use GM Goodwrench products on my 3 F bodies. I've seen aftermarket brands seized up after only 3 years.
Old 05-14-2014 | 04:56 PM
have a look here Power Window Motor
Old 05-15-2014 | 09:59 AM
After further inspection I realized there's a broken spring so I ordered a new assembly from the dealer it's only a few bucks more than the motor I'll have that baby in a little while anybody know how hard it is to put the regulator assembly?
Old 05-15-2014 | 08:44 PM
hardest part is finding a rivet tool big enough for the huge rivets, i bought one. if you know anyone with body shop or maybe stop by the local chevy shop and see if they can help out.
bd92rs
02-10-2012 10:52 AM
nmallory56
09-26-2009 03:18 PM
gotta99camaro
07-11-2009 01:07 AM
mikescars
70-81 V8 Tech
04-11-2008 05:49 PM
