96 z28 interior restore
Old Dec 6, 2014 | 10:54 AM
CountTripula's Avatar
Default 96 z28 interior restore
ok im wanting to breath new life in the inside of the car as it's starting to show its age and bring it back to life.
My question is can you remove 96 z28 interior restore-%24_35.jpg the two spots with the arrows mainly the top one?
I have to redo my t top headliner and i want that spot to match my headliner
Old Dec 6, 2014 | 01:19 PM
On the back side, look underneath the jute backing, and behind the fiberboard backer. Those trim panels are generally plastic and have tabs that stick through the door panel and are melted/mushroomed over to hold it in place. You'll want to creatively melt and push in those tabs back so that you can reattach them. A wider blade variable temperature soldering iron, like what's used to make stained glass would work for that.
Old Dec 6, 2014 | 01:45 PM
thanks, for the feedback this gives me another reason to buy a soldering iron cause i have to fix the BCM figure i would tackle all of it in one go when i have all the trim out
JPB
May 20, 2012 01:06 AM
przemekmsu
Apr 30, 2012 09:07 AM
Dan O
May 11, 2009 11:57 AM
grosloup
67-69 V8 Tech
Aug 3, 2008 11:13 PM
Gorn
Jan 3, 2008 03:40 PM
