4th gen Replace stock dash lights with white LED's?
#71
Are you talking about the bright light, turn signal, and brake lights on your gauges? If so, only the bright light and turn signals can be replaced. The brake light one is a soldered in there and is an LED. If you decide to do the bright light and turn signal lights, I suggest you get a blue led, and a couple green ones. While they would be this color even if the led's were white, it just makes the color much more vivid.
i was talking about the extereir light bulbs on the site superbrightled.com they have bulbs to replace those and i was wondering if theyd be bright then my existing ones...
#72
Glowing Rockstar
I Put The Rockstar under one of my blacklights.
It Does glow, but not as intensely as you would think
But it sure does glow. Probably not good for the health.
Pictures Don't Do Justice
But You Get The Idea
#73
Alright so I need qty 5 WLED-x5 LED Wide Angle LED bulbs for the gauges - which bulbs specifically for the green turn signal arrows?
Also is there any way to change the lights to LEDs on the stock Monsoon head unit (without breaking it lol)?
#76
Wait so to clarify, do some of the 5 WLED-x5 clusters that Zoilus recommended light up the turn signals / etc? Or are there separate bulbs... I'm a little confused as to how many bulbs there are under there.
#77
There are a total of 9 bulbs. 5 for illumination, 2 for the signals, 1 for brights, and 1 for the odometer. On mine, I got green bulbs for the signals, and blue for the bright. Makes it much more vivid.
#80
what in the hell hahaha
