Y pipe question
Old Jun 8, 2013 | 06:25 AM
808SS's Avatar
Default Y pipe question
I just installed the SLP Y pipe and now the factory tunnel brace don't fit. Is this normal with aftermarket Y pipes?
Or should I try to loosen the bolts on the Y pipe and try to jack the pipes up so it will clear the factory tunnel brace?
Also I just installed a Corsa catback will I notice a difference with the sound with the bigger Y pipe?
Thanks!
Old Jun 8, 2013 | 09:48 AM
i have kooks headers and y and they fit without the crossmember for headers. can you adjust it so it fits. i had one piece cut and a side streached so they fit together so it was easier to work with and seemed to fit better.
this is the header tunnel brace, i switched to the non header one for more ground clearance.
you can see the non header crossmember in this one.
Old Jun 8, 2013 | 10:12 AM
heres a link to spohns header tunnel brace without the torque bar relocation or driveshaft ring. Spohn Performance 1995 Chevrolet Camaro Tunnel Braces
Old Jun 8, 2013 | 11:48 AM
808SS's Avatar
I see thanks but is the stock brace suppose to fit? I cant see how much I can really push it up.
Old Jun 8, 2013 | 12:48 PM
some header setups require a header style crossmember. kooks is one of the only ones that does not. from what i can find slp should fit without issues. what y pipe did you get and from where?
Old Jun 8, 2013 | 01:11 PM
Failed Devices's Avatar
When I did my BBK longtubes, the crossmember did not fit. I debated on if I should add washers to the bolts to add clearance, but after doing searching on tech, it seemed most people just forget it or go aftermarket
Old Jun 8, 2013 | 11:45 PM
808SS's Avatar
I had tried to push up the SLP y pipe with no luck getting the stock brace to go back on so I had to use 2 nuts and longer bolts to space it down.
sikmov2
Jan 31, 2009 04:57 PM
tman21786
Jun 6, 2008 01:59 AM
fortdub99ss
Jan 23, 2008 01:15 PM
Saint_Ali
Jan 29, 2007 01:30 AM
