Wrong oil filter??
Old Nov 22, 2012 | 04:35 AM
cherijonmaui's Avatar
Default Wrong oil filter??
I had my oil changed the other day and my mechanic suggested a different filter with something called a check value or check ball since then I have had high oil pressure , the gauge jumps erratically and suddenly my engine misses when idling!!could it possibly have something to do with this new filter???HELP!!thanks
(i have a 01 v6 )
Old Nov 22, 2012 | 04:40 AM
MKCoconuts's Avatar
I don't know of any filters that have check *****. Maybe he meant anti-drain back valve? If that's the case, pretty much every filter has one now. Craw under if you can and try to see what brand of filter it is. As far as the gauge, it's possible he messed with something, to create new, false problems, to get you to come back spend more $$. I can't see a simple oil change creating such problems.
Old Nov 22, 2012 | 08:18 AM
what is the brand name of the oil filter. fram makes a low cost filter that can fail and mess with oil pressure. what all was done. please list parts from invoice, brand name of spark plugs, oil filter and if you have it what oil pressure sensor. i would first check the plug wires to make sure they are connected properly and in the right order.
Old Nov 22, 2012 | 09:21 AM
BasicConcepts's Avatar
Technical User
if he didnt gap the plugs right or if he hit the ground on the block and closed the gap it could cause a miss.
Old Nov 22, 2012 | 10:03 AM
All screw on filters have a bypass valve that opens when the filter gets clogged. I think your mechanic is giving you a snow jobs. Regardless of condition, oil filters do not cause an engine to misfire.
Old Nov 22, 2012 | 10:09 AM
the invoice is in the car at the shop but i will check a get back to you on that.thanks again for your help.happy turkey day
Old Nov 22, 2012 | 10:17 AM
ok thanks for that one too
Old Nov 22, 2012 | 11:41 AM
you have a good thanksgiving too. yep all it takes is to drop a spark plug while installing and it can cause a miss
Old Nov 23, 2012 | 09:35 AM
Default this is the new filter plus the oil mess still unsure where the oil came from ..still
Old Nov 23, 2012 | 09:58 AM
lose the fram oil filter and see what that does for oil pressure. need to clean the motor to make it easier to track the oil leak.
