Wont crank
Old Jun 19, 2018 | 10:21 AM
Sgtcraft's Avatar
Default Wont crank
Put a new motor in. The key was missing replaced with new steering column with key. Security light is on steady not flashing. When turn key on lights and all work car won't crank or even try. Can hear fuel pump come on. If I jump the starter it will crank and run for few seconds then cut off.. Please help motor is 3.8 v6
Old Jun 19, 2018 | 01:38 PM
Check out FAQ #25
https://camaroforums.com/forum/93-02...rt-here-38462/
Computer is looking for the original key frequency.
I don't remember the VATs system stopping cranking. That you will need to track down.
Old Jun 19, 2018 | 08:54 PM
check ignition fuse, heck check em all. lol. does sound like vats is not happy.
Old Jun 19, 2018 | 10:03 PM
peterpar's Avatar
I believe the VATS also controls the ground to the starter relay coil. Without the this relay, the key switch will not energize the starter. Going to have to find the resistive value of the original key and make a new key with that resistance, do VATS by-pass, or replace the BCM with a new one.
BigBZ28
Jul 21, 2020 01:02 AM
Sgtcraft
Jun 22, 2018 06:52 AM
karma187357
Oct 28, 2011 06:10 PM
blue max
Apr 2, 2009 10:18 PM
fbjunior
Jul 13, 2008 06:41 PM
