window problem
Old May 5, 2008 | 08:25 PM
dodge destroyer's Avatar
Default window problem
My passenger side works fine but my drivers side window wont roll down any more then a 1/4 in. and stops. then a it just clicks when ever i push the button. I found the clicking noise and its comind from a black box with a circuit board in it, under the dash on the fire wall.
Is the box called a "Comfort relay"????
Or is there something else wrong??? ALL FUSES GOOD/SWITCH IS GOOD!
Old May 6, 2008 | 01:15 AM
skylinrcr01's Avatar
Default RE: window problem
motor acting up?
Old May 7, 2008 | 12:40 PM
baseballer91's Avatar
happened before to me, be careful with it, if it falls down (and off the track) it can knock your door latch off its little hinge and it wotn open from the outside!!!
soounds like you're window motor just needs to be replaced..
its just one of those common camaro probs
Dro94Z28
Mar 28, 2014 01:23 PM
maroman209
Sep 13, 2009 12:44 AM
Rise65
Nov 6, 2006 11:09 PM
Saint_Ali
Sep 18, 2006 12:19 AM
