Will these rims fit? Falken 19"x8" - 5x120 - 38mm offset
Old Feb 16, 2012 | 01:40 AM
chevcamaro's Avatar
Exclamation Will these rims fit? Falken 19"x8" - 5x120 - 38mm offset
Will these fit?
Falken
75051017 Gunmetal 19 x 8.0 5x120 38mm 72.6mm
Wheels - Torque 5 - Falken Tire
I found a guy in the area that will sell me a set - new in the boxes for 500
there 5x120.7 vs the 5x120.7 , seems as though many people run that bolt pattern without any issues, but others that have had bad luck with it.
Aside from the bolt pattern, what about offset and size. they're 19" x 8" with a 38mm offset and 72.6mm center bore
Thanks
Old Feb 16, 2012 | 01:50 AM
chevcamaro's Avatar
Old Feb 16, 2012 | 01:59 AM
chevcamaro's Avatar
Old Feb 16, 2012 | 03:31 PM
chevcamaro's Avatar
Any advice?
Old Feb 16, 2012 | 04:38 PM
JGuy07's Avatar
Ok, the 5x120mm bolt pattern is not what the 4th gen is for. The 4th gen bolt pattern is 5x120.65mm so it's a little off and can put stress on the studs. And really, the most popular setup for these 4th gens isn't with 19" it's with 17's using 17x11 rear and 17x9 or 9.5 on front. The 38mm offset on the front will set the lip of the tire right at the edge of the fender which is the desired look most go for....the offset on the rear would have to be greater, 45-50mm, to keep them from rubbing inside or sticking too far out.
Are you sure you want to put 19x8 all the way around? If you do that offset will put them slightly tucked inside the fender well. But as for me, I'm cautiously using a set of GTO rims that were on when I purchased the car and have been keeping an eye on my studs for wear, the GTO is also a 5x120mm pattern. Unwanted stress on the studs.
Old Feb 20, 2012 | 07:19 AM
chevcamaro's Avatar
might go for it.. the price has been lowered to 400$ for all 4 rims, new in box - will be a while before i get them on the car anyways.. need another 1000 for tires
libertyforall1776
Apr 5, 2014 09:14 AM
AmericanMuscle1989
Jun 25, 2013 10:38 AM
acaciaavenue
Sep 26, 2010 07:18 PM
Stummy
Sep 14, 2009 04:07 PM
