will it fit?
Old Jul 24, 2013 | 04:42 PM
v64thgen's Avatar
Default will it fit?
will this raybestos caliper (fits the 98-02 Camaro) PN: RC10966QS
with this raybestos rotor PN: 56325
fit under a 16 in wheel on a 94 v6, don't know if it makes a difference but I have aftermarket wheels not the factory ones?
to save you guys from having to go look the rotors outside diameter is 10.94in, and the detentions on the caliper are 14.1x6.9x6.3 inches...according to the internet, haha.
Old Jul 24, 2013 | 06:08 PM
Massey's Avatar
Only if you change out the spindle. The 93-97 V6 and V8s used different spindles and brakes. In 98 all Camaros had the same front brakes and in 99 they all had the same rear as well.
Massey
Old Jul 24, 2013 | 06:24 PM
Your existing rotors are 278 mm in diameter (10.95"). So what's the reasoning behind wanting to use 1998-up ones?
Old Jul 24, 2013 | 06:30 PM
v64thgen's Avatar
I wanted to upgrade to what looked like better calipers, since I think one of them is on its last legs....pads are dragging a little....don't yet have the budget for bigger wheels so gotta stay with the same size rotors. What kind of modifications do I have to make to switch to the 98 and up spindles, and would it be worth it?
Old Jul 24, 2013 | 09:20 PM
Yes it is worth it but you need the caliper mounts also and your going to have to deal with the brake lines themselves.
The rotors are about an inch bigger the aluminum twin piston calipers with give more even pressure and dissipate heat much better.
Here is why you need spindles shown below is 2000 set of rotors set on my 96
I still plan on this upgrade on both my 96 and my 93, Rock auto had the rebuild kits on clearance so I bought a dozen
This shows the caliper mount your going to need along with the spindles. Carful buying them used they tend to seize up. The one in the picture is un-repairable.
Old Jul 25, 2013 | 01:43 PM
v64thgen's Avatar
thanks for the info gorn.
Old Jul 25, 2013 | 05:57 PM
libertyforall1776's Avatar
Time to upgrade those crappy de Carbon's Gorn!
Old Jul 26, 2013 | 07:40 AM
But the car only has 200K on it? Its on the list
My 93 has bilstein all around.
Old Jul 26, 2013 | 12:38 PM
Lightbulb
Seriously?! 200k on de Carbons still? WOW.
Might want to look into those Bilstein price range Koni STR.T shocks that just came out for F-Bodies...
Old Jul 26, 2013 | 03:14 PM
Naw car is going to my daughter. I will get her gas charged something but she rarley goes around a corner harder than gran-maw on the way to Church.
The shocks still pass PA law for saftey but I am not going to let my daughter drive on those things.
