wifes 96 transmisson failer
Old 05-24-2009 | 02:52 AM
phlemm's Avatar
Default wifes 96 transmisson failer
PLEASE Help.....wifes transmission just got rebuilt (shop saying it fine and ready to run , all well and good , but once i attached the linkage and gave her a test run ....park, reverse,neutral are all in reverse drive, funs fine , but when when i come to a stop , it seems that neutral is now drive reverse is neutral and park is reverse....ive no idea what the hell is goin off ccan anyone shine a light on this , im turnin grey as i type .many thank to all..phil
Old 05-24-2009 | 03:24 AM
And I'm going to guess that it won't go into park either?
Your shift linkage is out of adjustment at the trans.
Put your shifter in park, or as close to park as it will go.
Disconnect the linkage cable/rod from the shift lever on the transmission.
Push the trans lever all the way forward into park position (towards front of car).
Screw out the adjuster rod on the shifter cable until it fits comfortably on the arm on the trans.
Make sure the transmission now goes into the right gears to correspond with the indicator on the console.
Then put in a new cotter pin in the linkage.
Old 05-24-2009 | 03:54 AM
jagass's Avatar
Better take it back to the shop...
Old 05-24-2009 | 01:43 PM
02StanGT's Avatar
I'm guessing you missed the part where he said he was the one who installed the shift linkage.
Old 05-24-2009 | 05:10 PM
What I read into it is that he had the trans rebuilt and put the whole thing in himself? But it's clear he did some DIY stuff, linkage included.
Old 05-24-2009 | 05:28 PM
02StanGT's Avatar
That wasn't directed towards you, it was directed towards jagass, who always ends his sentences with... I'm with you, if the guy installed it all back, he would know how to adjust it as well. No reason to take it back to the shop.
Old 05-24-2009 | 06:54 PM
phlemm's Avatar
camero 69 , just got your responce , didnt know there was adjustment on the cable .....im on the case right now ...shall responde in a ickle while (wife will be chuffed to bits )...maybe she,ll buy me some of that dye for grey hair lol...thanks a bunch ..phil
Old 05-25-2009 | 04:01 PM
phlemm's Avatar
Default To camero 69
yippeeee....job all complete , grey hair dye on its why ...wifie all happy now ........thanks for information given, every ting works better than it did ...cheers mate ........great site , be around soon i sure , im a chevy owner too but a v8 suburban (86) once again many many thanks phil (hemm) phlemm
VALHAR
08-11-2013 02:19 PM
cplthomas
03-16-2013 09:42 PM
ocd dave
01-21-2010 07:00 PM
dk666
11-02-2009 10:53 PM
