WHOLE dash removal?
Old Jul 25, 2010 | 07:02 PM
MelloYello's Avatar
Default WHOLE dash removal?
im stripping my engine bay, and i cant figure out how to get the dash out (at least glove box and pass side air bag) so i can remove the blower motor. any hints?
Old Jul 25, 2010 | 09:31 PM
so you want to get the heater fan out or you want to take the dash off? heater fan is easy. like four screws and a wiring connector to unplug.
Old Jul 26, 2010 | 04:53 AM
1augapfel's Avatar
What does stripping the engine bay have to do with removing the instrument panel/dash?
Old Jul 26, 2010 | 10:56 AM
Massey's Avatar
So he can take the heater box out of the car to give him better access.
To remove the heater box you will need to remove the entire dash.
Remove steering column
Gently lift up on the plastic cover between the glass and the dash pad... This is held in with velcro like pads and push clips. Careful not to pull out the LED and the headlight sensor.
Crawl under dash and remove all grounds (some are behind the kick pannels), remove all connections to the taillights, doors and external harness.
Remove the union for the heater controls behind the glove box, remove the heater controls (dont forget the cable going to the mix door, removing it from the heater box works best)
Remove bolts holding dash to the cowl under the dash.
Remove bolts from top of the dash
carefully pull the dash out from the cowl and make sure that all the hoses and wires are properly disconnected and nothing is getting pulled out of where they need to be. The dash will come out with the ducting and wiring harness still attached, the passenger airbag will also come out with the dash.
Massey
Old Jul 26, 2010 | 03:13 PM
MelloYello's Avatar
thanks massey, thats Xactly what i needed to know!
Old Jul 26, 2010 | 03:43 PM
KissMyTush's Avatar
Massey is the ****! lol!
Old Jul 26, 2010 | 05:24 PM
Massey's Avatar
um.... forgot to mention that you will need to remove the console as wel there are 2 bolts in the middle of the dash behind the console.
Massey
juice+
May 6, 2013 12:17 PM
Chaotic94
Jun 5, 2012 11:06 AM
kleanrides
LS Series Tech
Oct 19, 2011 07:54 AM
cadmanof50s
Jul 29, 2010 09:10 AM
