Whiny fuel pump after filter replacement
Hi all,
'98 SS here with 45k miles. I replaced the fuel filter today with a K&N PF2100 (as suggest by Rick's Camaros online). I started the car to cycle fluids after the replacement and everything was normal for 2-3 mins. Then I started to hear the fuel pump whine. Quite noticeable from inside the car and down by the rear end. The pump continued to whine until I shut the car off after it reached operating temp.
Did I buy the wrong K&N filter for the car? It was the same size as the stock filter.
did you get the arrow pointing the right way when installed, pretty sure it will only go in one way. changing filter should not make the pump react this way, may be the pump is not happy, how old is it
