Where to refill diff oil
Old Aug 30, 2012 | 01:16 PM
djsquare1's Avatar
Default Where to refill diff oil
My rear diff has a slow leak. It's wet and there are a few drip marks in my parking spot. I understand I will have to replace the gasket, but can I just top it off for now? Is there a plug anywhere to check the level?
Anyone with experience changing out this gasket? Tough job or easy?
Old Aug 30, 2012 | 01:57 PM
jkeaton's Avatar
Should be a plug. Unbolt the cover, scrape off the old gasket, install new gasket, bolt the cover back on and refill. Don't forget the additive if you have limited slip.
Old Aug 30, 2012 | 02:55 PM
djsquare1's Avatar
Awesome, Ill get under it and look for that plug and make sure the level is good. As far as swapping the gasket goes, that sounds easy as pie.
Thanks!
Old Aug 30, 2012 | 02:58 PM
MKCoconuts's Avatar
Plug will be passenger side, top of diff. You'll need a 3/8 ratchet and small 3/8 extension to get it out. Be careful not to strip it. I'd also stop at a parts store and get a allen plug to make it easier next time. Gasket replacement is simple. Make sure to use the correct gear oil, I believe 75w-90 is it.
Edit: It's 80W-90, 1.75 quarts.
Old Aug 30, 2012 | 03:19 PM
Z28Camaro98's Avatar
How often should the rear diff oil be changed?
Old Aug 30, 2012 | 03:22 PM
MKCoconuts's Avatar
I'll check my manual later, but I believe it's every 50k or so.
Old Aug 30, 2012 | 06:30 PM
jkeaton's Avatar
What's the additive for lsd's
Old Aug 30, 2012 | 08:07 PM
MKCoconuts's Avatar
I can't remember who makes it, but it's called Posi-trax. You can find it at any local parts store. However, depending on what gear oil one was to go with, some say they do not require it, such as the Lucas type. While others say that if you don't put the additive in, you'll get lots of strange noises from the rear end, I've used the Lucas stuff and haven't had anything out of the ordinary, so that is a personal choice. Will adding the additive to the Lucas hurt it? Certainly not. Also, do NOT use synthetic with a LSD rear.
Old Aug 30, 2012 | 09:28 PM
whats wrong with a synthetic?
Old Aug 30, 2012 | 09:54 PM
MKCoconuts's Avatar
Supposedly ruins the clutches in the rear. Not 100% sure on whether that's true or not, but I never took the chance to find out.
