Where is the factory amp?
Old Mar 7, 2008 | 09:19 PM
Rakeris's Avatar
Default Where is the factory amp?
I was wondering if anyone knew where the factory amp was in an 01 Z28 with the premium sound package?
Thanks!
Old Mar 8, 2008 | 02:39 PM
libertyforall1776's Avatar
Default RE: Where is the factory amp?
Rear passenger quarter-panel area.
Old Mar 8, 2008 | 02:50 PM
6v49der's Avatar
Youlll have to take out the spare tire and jack to get it out if thats what you plan on doing. Its bolted to a big piece of plastic thats pretty almost right over the passenger rear wheel.
Old Mar 8, 2008 | 07:29 PM
Rakeris's Avatar
Found it, thanks a lot!
Old Mar 10, 2008 | 04:39 PM
kamaro68's Avatar
Great, now that I know where it is located I can bypass the factory amp.
I installed a new high watt stereo. I think the amp is multiplying the wattage because I turn my head unit on low volume and it is very loud!
Old Mar 11, 2008 | 01:55 PM
Ya need to find a level regulator and you can use the stock Amp with your new stereo
For Bose Amps, use Scosche OEA-4 (only $12.46!)
http://www.beegool.com/product_info....ducts_id=22435
For Monsoon Amp-- I'm not sure, anyone know? I wonder if the same Scosche OEA-4 would work -- anyone try it?
Old Mar 12, 2008 | 05:01 PM
kamaro68's Avatar
I wish I would have known about this a long time ago.
I think I have Bose? Not too sure...
Either way I should really look into this.
Old Mar 12, 2008 | 05:58 PM
Look on our headunit -- does it say Bose or Monsoon? Then you will know.
If it says Delco, then you have no amp.
ORIGINAL: kamaro68
Old Mar 12, 2008 | 06:50 PM
kamaro68's Avatar
Mine says Alpine...
Seriously though...I think it said Delco. I think the speakers say Delco as well. There is a sub in the trunk. I thought that Bose made the units for Delco?
Old Mar 12, 2008 | 09:20 PM
95slvrZ28's Avatar
The head unit will say "Bose-ACDelco" on it if you got the premium sound option. All the speakers should say "Bose."
ragtag
Jun 29, 2015 09:43 AM
Red-Cricket
Jan 12, 2011 10:51 PM
1rad68
Jan 30, 2010 02:02 PM
Puck90a
Jul 21, 2007 02:24 PM
