wheel help
Old Aug 18, 2009 | 01:42 AM
Xx3800xX's Avatar
Default wheel help
Sorry if I'm posting in the wrong section, but does anyone know if some older 15x7 Iroc wheels will fit on a 2001 v6 Camaro?
Old Aug 19, 2009 | 11:26 AM
depends on the offset. they well probly fit but if the off set is not right the tires will stick way out.
Old Aug 19, 2009 | 12:41 PM
Xx3800xX's Avatar
okay thanks, ill just have to try it out with one of my bud's wheels and see how it looks
Old Aug 19, 2009 | 03:12 PM
Brake caliper clearance could be another issue. As long as you have more than 1/2" wheel-to-caliper clearance with your present wheels, the 15's should bolt on fine. How much they fill the fenderwell is what you'll find out when you fit them on.
Old Aug 20, 2009 | 12:27 AM
Xx3800xX's Avatar
yeah, im just afraid they might look too small, did they make bigger fender wells on the newer(92-02) camaro's or what? if not, then why does the 15's look so slick on the 80's and well we shall see on mine.
Old Aug 20, 2009 | 12:31 AM
Stix80's Avatar
no newer camaros have a negative offset on them so even if they do fit over the brake calipers and everything they will stick way far out and they have to be wheels off of an rs because the irocs only had 16s on them even though they are the same design
