Whats wrong with v6 my car then.
Old Sep 25, 2011 | 02:13 PM
94ChevyCamaroV6's Avatar
What am I suposed to use then to make this sound go away and make the belt stop squeaking.
Old Sep 25, 2011 | 02:14 PM
JGuy07's Avatar
Well people can offer opinions and help all day, but until you test things out and work for a solution you're not getting anywhere.
Old Sep 25, 2011 | 02:29 PM
I am trying to find out what to put on the belt to make It stop squeaking then.
Old Sep 25, 2011 | 02:49 PM
JGuy07's Avatar
Don't put anything on the actual belt, the problem is most likely one of the pulleys the belt is on. That was mentioned in an earlier post as well.
The main concern would be the starting problem first, the noise is inconvenient for the time being. Charge or replace battery and see if that makes a difference with the starter, if not then you know you need to check the starter.
Then, move onto checking your belt system and pulleys. Make sure your belt isn't corroded or cracked/worn. Check each pulley and make sure they are able to spin freely. Check to see if there is any play with the pulleys( if they wobble or seem loose).
Old Sep 25, 2011 | 03:06 PM
Im guessing If I replace the battery that will take care of the problem because this has happened before I think but I will see what walmarts return Is then my question Is Is It bad to try to turn those pulleys or anything because will the car start up I know It may be a dumb question but Im Just wondering If It can make the car start etc; The belt we are talking about Is the one that Is In kinda the left front of the engine then.
Old Sep 25, 2011 | 03:23 PM
JGuy07's Avatar
The serpentine belt is what we're all talking about. Release the belt tensioner to be able to take the belt off to allow you to more easily check the pulleys.
Old Sep 25, 2011 | 04:07 PM
I charged the battery and the car started and there Is a squeaking coming from one of the right three pulleys I will post another video then.
Old Sep 25, 2011 | 04:52 PM
Lol, Onother person looking for some magic elixir in a bottle to fix car problems.
Old Sep 25, 2011 | 05:04 PM
Im not looking for magic **** I am wondering If there Is a spray that I can put on to fix the sqeaking I didnt ask for a smart alic response then.
Old Sep 25, 2011 | 07:00 PM
  #20
3800camaro's Avatar
Check your alternator. It might not be charging your battery properly and could also be causing the squeak.
