Whats wrong
like its just air. half way. like if i turn the thing to ac it is the same temp heat as if i had the heat on. and vica versa. air just blows but it doesnt change to hot or cold
Have you tried replacing the controls module yet? Alternately, the linkage may be worn that makes the change behind the controls module -- I think you need to do some tear-down to see what's up.
Also, you can try going to a shop that gives free estimates and have them tell you what's wrong and what they would do...
The **** didn't break did it? When I got my car one was broken and I couldn't change any of my settings. It had been glued back together before, but it was too broken to fix it again.
