What should I do?!?!
Old Aug 26, 2009 | 01:24 PM
GoofieJ21's Avatar
Default What should I do?!?!
I just found out my "syncros" in my transmission are worn out. I talked to two shops and they both quoted me $2000 - $2500 to pretty much rebuild it. I've already put about $2500 in the car since I bought it almost 3 years ago. I really don't have the money right to to fix it right now. I was thinking of either selling it the way it is and get as much out of it as I can or driving it until it isn't drivable any more and sell it. I have no idea what I can get out of it but I'm hoping around $2k. If I can get 2 out of it then I might be able to get around enough money to upgrade to a Z28. So should I fix it and drive it or sell it and buy a 2000's Z28? Also the 2010 Camaro is out of the question.. I'm a broke full time college student . Thanks guys.
Old Aug 26, 2009 | 06:07 PM
Learn the art of double clutching, and you won't need any stinking synchros.
Old Aug 26, 2009 | 06:45 PM
cbr600rx7's Avatar
I would say that is a little high for a rebuild on a T56. You can pick up a built one from RPM transmissions for about 2300-3000 depending on what level you are going for.
Old Aug 26, 2009 | 07:55 PM
02StanGT's Avatar
if that's high for a t56, then that's crazy for his t5
Old Aug 26, 2009 | 08:14 PM
Y2K's Avatar
Y2K
Pick up a used one at a wrecking yard.
Old Aug 26, 2009 | 11:31 PM
GoofieJ21's Avatar
yeah I thought it was steep too but I took it to another shop and they gave me the same quote. There's just no way I can afford to put any more money into this car. How exactly does this so called double clutching work? If I can figure out a way to drive it like it is for a while it would help out a lot. I've heard the term "double clutching" before but have no idea how to do it?
Old Aug 27, 2009 | 04:34 AM
02StanGT's Avatar
push clutch in, take it to neutral, release clutch, push clutch in, put in gear, release clutch
Old Aug 27, 2009 | 08:46 AM
Transmissions in cars of yesteryear didn't have syncros. Double-clutching was the way you HAD to shift.
Old Aug 27, 2009 | 09:54 AM
stealthy95z's Avatar
I never understood that double clutch crap. oldest manual car I drove was a 74 beetle. didn't need to double clutch that, so what exactly does yesteryear consist of? lol
Old Aug 27, 2009 | 11:26 AM
Around the early 1930's is when synchros came about. Some, not all cars had them at that time.
