What gears are in my 96 z?
Old Aug 21, 2010 | 02:54 PM
MaVeN's Avatar
Default What gears are in my 96 z?
What Title says.
Old Aug 21, 2010 | 03:34 PM
Most likely round ones. Seriously, it depends on the option. Check label in glove box.
The most accurate method of determining a rear axle gear ratio is to look in the vehicle manufacturer's service manual. The following Regular Production Option (RPO) codes identify the rear axle and trans axle overall final drive gear ratio's. These codes can be located on the RPO sticker in the glove box or in the trunk on most GM vehicles. These codes are arranged in alphanumeric order. Please refer to the information below
RPO CODEDESCRIPTION
RATIO
F16TransAxle Final Drive
2.53
F17TransAxle Final Drive
2.84
F18TransAxle Final Drive
2.65
F25TransAxle Final Drive
3.32
F29TransAxle Final Drive
2.82
F36Axle Front
2.19
F45Axle Front
2.93
F47Axle Front
2.73
F57Axle Front
3.15
F62TransAxle Final Drive
2.39
F67TransAxle Final Drive
3.19
F68TransAxle Final Drive
3.45
F75TransAxle Final Drive
3.18
F77TransAxle Final Drive
3.73
F79 TransAxle Final Drive
2.97
F82TransAxle Final Drive
3.23
F83TransAxle Final Drive
3.05
F90Axle Front
2.73
FA0Rear
5.77
FA1Rear 2 SPEED
4.88/6.94
FA2Rear 2 SPEED
4.88/6.94
FH5TransAxle Final Drive
2.81
FH6Axle Front
3.64
FH7TransAxle Final Drive
4.12
FH8Axle Front
2.40
FH9TransAxle Final Drive
2.60
FJ1Axle Front
4.18
FJ2Axle Front
3.74
FJ3TransAxle Final Drive
3.35
FJ4Axle Front
4.53
FJ5Axle Front
4.19
FJ7Axle Front
4.56
FP0TransAxle Final Drive
2.55
FP1TransAxle Final Drive
2.72
FP2TransAxle Final Drive
3.58
FP3TransAxle Final Drive
2.73
FP4TransAxle Final Drive
2.69
FP5TransAxle Final Drive
2.95
FP6TransAxle Final Drive
3.54
FP7 TransAxle Final Drive
3.73
FP8TransAxle Final Drive
3.54
FP9TransAxle Final Drive
3.54
FQ2TransAxle Final Drive
3.48
FQ3TransAxle Final Drive
2.86
FQ4TransAxle Final Drive
3.57
FQ6 TransAxle Final Drive
4.12
FQ8TransAxle Final Drive
2.96
FQ9TransAxle Final Drive
3.21
FR2TransAxle Final Drive
2.93
FR3TransAxle Final Drive
3.69
FR6TransAxle Final Drive
3.84
FR7TransAxle Final Drive
3.95
FR8Axle Front
4.17
FR9TransAxle Final Drive
3.29
FV0TransAxle Final Drive
3.67
FV1 TransAxle Final Drive
3.72
FV2TransAxle Final Drive
4.18
FV3TransAxle Final Drive
3.11
FV4TransAxle Final Drive
3.71
FV5TransAxle Final Drive
4.19
FV6TransAxle Final Drive
4.24
FV7TransAxle Final Drive
4.29
FV8TransAxle Final Drive
4.31
FV9TransAxle Final Drive
4.53
FVOTransAxle Final Drive
3.67
FW2TransAxle Final Drive
3.06
FW3TransAxle Final Drive
4.02
FW4 TransAxle Final Drive
3.89
FW5 TransAxle Final Drive
4.10
FW6 TransAxle Final Drive
3.42
FW7TransAxle Final Drive
3.83
FW8TransAxle Final Drive
4.28
FW9TransAxle Final Drive
3.43
FWSTransAxle Final Drive
4.10
FX1TransAxle Final Drive
3.94
FX2TransAxle Final Drive
2.66
FX4TransAxle Final Drive
3.35
FX8TransAxle Final Drive
3.61
FY1TransAxle Final Drive
2.36
FY3TransAxle Final Drive
3.79
FY5TransAxle Final Drive
3 52
G11TransAxle Final Drive
2.56
G44 Axle Rear
3.07
G72Axle Rear
2.14
G75Axle Rear
3.62
G76Positraction Rear
G80Axle Positraction, Limited Slip
G81Positraction Rear Axle
G82Axle Rear
4.56
G84Axle Rear
4.10
G86Axle , Rear, Limited Slip
G87Ring Gear, 8.50 Inch
G89Ring Gear, 7.50 Inch
G90Rear
3.15
G91Special Highway Rear Axle
3.08
G94Axle Rear
3.31
G96Axle Rear
3.55
G97Axle Rear
2.73
GH0Axle Rear
3.54
GH2Axle Rear
2.29
GH3Axle Rear
2.77
GH4Axle Rear
2.92
GH7Axle Rear
2.73
GJ1Axle Rear
5.38
GJ2Axle Rear
5.13
GK7Axle Rear
4.78
GK8Axle Rear
4.33
GK9Axle Rear
4.63
GL0Axle Rear
5.13
GL3Axle Rear
6.17
GM1Axle Rear
2.59
GM2Axle Rear
3.44
GM3Axle Rear
3.45
GM4Axle Rear
3.67
GM5Axle Rear
3.89
GM6Axle Rear
4.22
GM7Axle Rear
3.68
GM8Axle Rear
2.56
GN9Axle Rear
4.11
GS1Axle Rear
2.73
GS3Axle Rear
3.73
GS4Axle Rear
3.70
GS5Axle Rear
4.11
GS6Axle Rear
4.56
GS8Axle Rear
3.94
GT1Axle Rear
2.56
GT2Axle Rear
2.29
GT4Axle Rear (DUP WITH 5 X 1)
3.73
GT5Axle Rear (DUP WITH GT8)
4.10
GT7Axle Rear
3.33
GT8Axle Rear (DUP WITH GT5)
4.10
GU1Axle Rear
2.41
GU2Axle Rear
2.73
GU3Axle Rear2.93GU4Axle Rear
3.08
GU5Axle Rear
3.23
GU6Axle Rear
3.42
GU7Axle Rear
2.77
GU8Axle Rear
3.90
GU9Axle Rear
3.91
GV0Axle Rear
3.55
GV1Axle Rear
2.73
GV2Axle Rear
5.83
GV3Axle Rear
3.08
GV4Axle Rear
3.36
GV5Axle Rear
3.55
GV7Axle Rear
4.11
GV8Axle Rear
2.72
GV9Axle Rear
4.25
GW2Axle Rear
2.56
GW3Axle Rear
2.56
GW4Axle Rear
3.31
GW5Axle Rear
2.73
GW6Axle Rear
3.27
GW8Axle Rear
4.10
GW9Axle Rear (DUP WITH GU3)
2.93
GX1Axle Rear
3.70
GX2Axle Rear
3.07
GX3TransAxle Final Drive
3.33
GX4Axle Rear
3.75
GX5Axle Rear
4.09
GX6Axle Rear
3.53
GX8TransAxle Final Drive
3.74
GY2Axle Rear
3.31
GY3TransAxle Final Drive
4.29
GY4Axle Rear
4.53
GY5Axle Front
3.65
GY7TransAxle Final Drive
4.18
GY9Axle Rear
4.31
GYSTransAxle Final Drive
3.65
H01Axle Rear
3.07
H04Axle Rear, SINGLE SPEED
4.11
H05Axle Rear
3.73
H12Axle Rear, 21000 LBS, EATON 21065S, SINGLE SPEED
H42Axle Rear
6.17
H43Axle Rear
5.43
HA3Axle Rear, SINGLE SPEED
5.29
HC4Axle Rear
4.56
HC7Axle Rear, 7500 LBS, SINGLE SPEED
5.13
HC8Axle Rear, SINGLE SPEED, TRUCK
3.21
HC9Axle Rear
5.13
HE3Axle Rear, 3500 LBS, SINGLE SPEED,
3.07
HE4Axle Rear
3.40
HF7Axle Rear, 10000 LBS, DANA 70, SINGLE
4.56
HF8Axle Rear
4.88
HJ1Axle Rear
4.55
HJ2Axle Rear
5.86
HJ3Axle Rear
4.75
HJ4Axle Rear
6.50
HJ5Axle Rear
5.57
HJ6Axle Rear
4.78
HJ7Axle Rear
4.88
HK1Axle Rear
2.87
HK3Axle Rear
6.14
HK9Axle Rear 10000 LBS, SINGLE SPEED
5.86
HO4Axle Rear
4.11
HO6Axle Rear
4.63
The following figure presents differential cover/cover gasket shapes. Counting cover bolts and cover shapes is a common method to determine which ring gear diameter differential you have in your Rear wheel drive vehicles. See following paragraph for selection of correct Dana parts.
Old Aug 22, 2010 | 12:17 AM
All that is assuming no previous owner ever changed your gears from what was factory installed. And considering all the members just here who want to or do change their gears, the RPO code is useless information in those instances. The RPO code will tell you "what could be" or "might still be" in the rearend.
Old Aug 22, 2010 | 03:17 PM
Very true, may just have to get down and dirty, take off the differential cover, count the number of teeth on the ring and the pinion gears, and do the unthinkable, like long division. lol
Old Aug 22, 2010 | 03:21 PM
MaVeN's Avatar
Well, the guy I bought it from drive it off the lot in dec of 95. He said he did nothing to it but changed the oil every 2k miles. He had to put a new compressor and window motor, but that's it.
Old Aug 22, 2010 | 03:44 PM
In that case check the chart and the sticker in the glove box and look for the GU- code.
Old Aug 22, 2010 | 06:53 PM
Did the previous owner ever change the oil in the rearend? If not, you'll want to pop the cover off anyway, and change the oil. And don't forget the limited slip additive.
Old Aug 22, 2010 | 07:42 PM
microkid's Avatar
March 2011 ROTM
Technical User
or you can tell me your tire size and engine rpm's at 60mph in the top gear and i can figure it out. is it a manual or automatic?
sepadowd
Aug 4, 2011 07:59 PM
91camaro350
82-92 V8 Tech
Aug 5, 2010 10:28 AM
gfrench
Jun 19, 2010 10:16 PM
1bad96Z28
Jun 9, 2007 09:12 AM
