What else is there?
Old May 3, 2011 | 09:08 PM
timmyz28's Avatar
Yeah, I can get the Silverstar Ultra highs and lows from my Advance Auto for like $50 each pair. I'm going to buy those fogs and interior lights possibly right now
Old May 3, 2011 | 09:25 PM
BasicConcepts's Avatar
Technical User
you do know you have to "modify" the headlights to work because yours are sealed beam
Old May 3, 2011 | 10:22 PM
timmyz28's Avatar
Yeah I know, I read either a sticky or just a post about it in another section.
Old May 4, 2011 | 11:01 AM
je$$up97's Avatar
You could also order eurolamps with the 9005, 9006 already in them. Any 880 series bulb will work in the fogs.
How do you do the mod for all 6 lights?
je$$up97's Avatar
also, try a heat gun rather than a hair dryer...higher temps without all the airflow.
Old May 4, 2011 | 11:49 AM
timmyz28's Avatar
My heat gun broke. I could maybe borrow someone elses. But I went to the auto body store and bought a pinstripe eraser wheel and they said that works for tape so ill try that when I get home.
The fog bulbs just twist out so they are an easy replace. With the headlights, you have to take the bulbs out the sealed housings and RTV seal the new bulbs in the case so they are water proofed.
Old May 4, 2011 | 12:39 PM
Adam9066's Avatar
this ill sound crazy but i used peanut butter on a bumper sticker that some moron stuck on my cobalt and it helped a friend told me to use it. I put it on and let it sit for a few hours and came up. Its not a bumper sticker but maybe it ill work
Old May 4, 2011 | 01:11 PM
timmyz28's Avatar
Lol that's too crazy for me to try. I got an eraser wheel, I know it will work.
Old May 4, 2011 | 08:09 PM
timmyz28's Avatar
Well the eraser worked like a charm. Got almost all of it off, but it at least broke all of it up, so the little bit of residue left scrubbed right off. I will get pictures tomorrow of it without molding if the weather is nice. Only bad thing is the paint is chipped and discolored on the passenger and looks real ugly. Might just try to touch that up for a little.
Old May 5, 2011 | 04:04 PM
  #20
Chaotic94's Avatar
September 2011 ROTM
Pull your fuse box, and under your fog lamp fuse there are some wires coming out. There is only 1 green wire coming out from under the fog light fuse. Cut the green wire and the end that is still going to the fuse box just needs to be grounded somewhere. The other end of the wire can be taped off so it doesn't touch anything. If you have any other questions, PM me
