What do you gus think about the Edelbrock 7109 GM LT1 LT4 RPM Air Gap Intake Manifold
Old Jul 7, 2008 | 01:34 AM
KING_RU's Avatar
Default What do you gus think about the Edelbrock 7109 GM LT1 LT4 RPM Air Gap Intake Manifold
Is it a good investment or i can do without?
Old Jul 7, 2008 | 06:53 AM
aightball87's Avatar
Default RE: What do you gus think about the Edelbrock 7109 GM LT1 LT4 RPM Air Gap Intake Manifold
depends, what other mods do you have
Old Jul 7, 2008 | 10:29 AM
cbr600rx7's Avatar
It offers less heat soak then the stock manifold and over all has a lot more flow then the LT4. If you are bolted with headers, exhaust, intake it could be a good pick.
Old Jul 7, 2008 | 01:17 PM
95slvrZ28's Avatar
In my opinion it's not worth the money. Save yourself some cash and get your stock intake ported to match you heads (if you have aftermarket heads) and then get the front ported so you can run a 58mm TB (if you're making over 350 RWHP). The stock LT1 intake can flow more than enough to support 400+ RWHP if you have a 58mm TB on the front.
Old Jul 7, 2008 | 03:24 PM
viciouZ's Avatar
Slvr beat me to it. Not really worth it. Port the stocker. Sit down and get some quality time with the dremel.
Old Jul 7, 2008 | 06:02 PM
cbr600rx7's Avatar
I dont recomend doing it your self for the first time. But porting is a good way too go. SLVR gives good advise so if he said that then it must be true .
Old Jul 8, 2008 | 01:26 AM
95slvrZ28's Avatar
I'll also say that you should probably take it to a professional for the port matching, you don't want to grind the intake runners so thin they warp or burn through. Porting for the TB could be done with a dremel though, that's how I was planning on doing mine
Old Jul 8, 2008 | 11:51 AM
viciouZ's Avatar
I dremeled my own. I wouldn't recommend doing it if you have no experience with a dremel, its a good idea to practice on some scrap. If you use a lower speed you won't take off too much material, so its not that big of a deal. Its not like you are using a monster power tool thats going to tear the aluminum to shreds the second you touch it. It took me several hours.
Old Jul 8, 2008 | 03:01 PM
z28rob18's Avatar
alright i keep hearing this manifold isnt good i actually bought it b4 i found this site i got it and the hot cam from ebay for 300 i though it was an awesome deal why is it so bad and wat can i do to make it better also is the lt4 hot cam a good cam or should i sell it and get another?
Soundwave
Jan 14, 2011 06:05 PM
zaroot
Nov 9, 2008 10:01 PM
z28rob18
Jul 11, 2008 01:24 PM
Saint_Ali
Apr 1, 2007 12:12 AM
martian
Sep 20, 2006 05:08 PM
