weather seal at the base of the steering column
Old 07-29-2017, 07:34 AM
Default weather seal at the base of the steering column
I am working on my 93, where the steering column meet the floor/firewall it has no seal. It is just metal to metal. I though I remember rubber bulging out of there on other cars. The other symptom I have is that the column is "in to far" meaning the key almost hits the dash when you turn it on. Based on the shinny overly long bolts I would say the column has been out before.
I check the parts book and I see nothing calling for a seal under the column exploded view. Next I will remove the cover on my 2000 and look at it.
Is there a seal? or why is the ignition cylinder (key) 1/4" closer to the dash then either my 1996 or my 2000?
Old 07-29-2017, 08:21 AM
not showing any seal or insulator in my 93 parts manual. ill have to have a look at mine later.
Old 07-30-2017, 04:38 PM
Where you at Socom. You had your column out a few times?
Old 07-30-2017, 08:02 PM
mine looks metal to metal from the inside, from engine compartment there is some foam looking stuff around the column
Old 07-31-2017, 10:45 AM
took some pics. looks like there is a seal there, i can not find one anywhere though.
Attached Thumbnails weather seal at the base of the steering column-p7310096.jpg   weather seal at the base of the steering column-p7310094.jpg   weather seal at the base of the steering column-p7310086.jpg
Old 08-27-2017, 10:13 AM
Thank you craby
I reinstalled the column and got everything working. The key almost hits the dash with everything bolted where it should be. After researching this in the manual I found the column is most likely collapsed. This would be due to a wreck. Makes sense since the front end was replaced.
This sucks.
Old 08-27-2017, 05:54 PM
bummer,,, maybe you can sell it as a modified coluum for short fat people,,, lol.
rs657f
12-08-2015 01:14 PM
Badrs2810
06-04-2010 01:10 PM
thehatch2002
05-12-2007 11:12 PM
krazycamaro84
11-13-2005 10:18 AM
Quick Reply: weather seal at the base of the steering column
