Water in engine
Old Nov 9, 2010 | 02:46 AM
  #21
1augapfel's Avatar
I've seen other posts that say the 3.4 intake and exhaust pushrods are different lengths. I didn't find that to be the case when I overhauled my 94. I checked my box of extra parts (from the screw job junkyard 3.4) and all the pushrods look to be the same length. Just to be sure I wasn't losing my mind I checked the parts manual pdf. It says that the 3.4 uses pushrod #476525, quantity 12.
The pdf also says that the 3.8, the LT1, and the LS1 each use different pushrods but the intake and exhaust are the same for a given engine. So I'm scratchng my head wondering where this pushrod length thing is coming from???
Old Nov 18, 2010 | 03:05 PM
  #22
ChandlerMotorsports's Avatar
Former Sponsor
Wow man, that's tough. At least you didn't lose the whole ride! But yeah, two minutes of flames is a big deal!
Old Nov 18, 2010 | 04:04 PM
  #23
KillNThrill24's Avatar
i have also heard that GM's DexCool eats through gaskets like no tomorrow and after about 150,000mi they start to take their tole on the intake gasketts, i had a 3.4 gm engine that the intake gasket went because of the orange DexCool. needless to say, if i ever see the orange, i flush it and switch it to yellow
Old Nov 18, 2010 | 11:13 PM
  #24
You may want to check the vacuum hose going to the regulator, just in case the fire got to it. A leaky hose will result in high fuel pressure at idle and normal driving.
fuelalterd
Jun 24, 2013 05:57 PM
hotrodtom
Sep 10, 2012 04:54 PM
Rahbit
Apr 4, 2012 08:21 PM
Rahbit
Apr 1, 2012 09:52 PM
kamaro68
Mar 27, 2008 08:07 AM
