Upgrading from monsoon speakers?
Bah, those Type R's look good...
You think I could just do the doors without the other 6 speakers?
That might cause issues if I eq just the door speakers and none of the others.
I'd have to leave all my ***** on my eq at neutral or just not wire the eq to the front speakers.
If I can get the two type r's in the doors without it causing problems then I'll do that to finish up upgrading my system.
But, would I need a new amp for just those two? I think the monsoon one is 500w peak, 200 RMS. Which isn't bad..
But if it's wired to all 8 speakers, they will only get like 25w each RMs which is poo. the alpine type r's can take 100 rms @ 4 ohms.
As for your trunk rattles, you could use the dynamat wedge pak (one 18x32 sheet) on your trunk lid. That's what I did. No more rattles (:
![Icon Dopey](https://camaroforums.com/forum/images/smilies/icon_dopey.gif)
My speakers are all running off the headunit (X and R), so I'd say no. They can take that much, but you won't ever (I believe) be feeding it that much. An expert might want to chime in here.
I'll look into the Dynamat a little bit more possibly this week. If that got settled, I'd be good for a while I think! Well, until I get a better box that is.
Guitar, can I see a pic of your front speakers, are they clean?
Alpine SPE-6000 Coaxial 2-way 6-1/2" Car Speakers
It says those won't fit 2001 chevy camaro but I'm pretty sure they will
They are mounted behind the factory mesh, so yeah I suppose they look fine. They are mounted with just the woofer, I didn't put the Alpine grills on them as I figured no need. I'm not taking the door panel off lol, but from the picture you'll see they fit fine behind it. The crossovers are somewhere in the door where the window motor would go; didn't want to hard mount it. Everything fits good and nothing moves around.
![](http://img717.imageshack.us/img717/3042/img20110928195154.jpg)
That's legit.
I thought they would look like the ones in the back or have wires sticking out, not look right, etc
I guess I'll go with the r's coaxials but they're expensive compared to E's and I don't see why I need them if I'm not going to use the extra power that R's provide..
I would get type r components but I heard type-r tweeters are kind of crappy and distort more than monsoon at higher volume levels..
Yeah they are 6.5" all around.
I just got a lot of money so I'm going to get two sets of
http://www.sonicelectronix.com/item_...e-SPR-60C.html
These for the front and back to replace the 8 monsoon speakers.
Are the 4 tweeters ( 2 front/back) hard to find and replace?
Alpine SPR-60C (SPR60C) 6.5" 2-Way Type-R Component Car Speakers
But doesn't the monsoon 8 speaker system have tweeters in the back?
It doesn't make sense having 6 alpine speakers and 2 monsoon tweeters, i might just remove them entirely.
I'll go with components in the front, like you and you said you had composites in the back, right? I want a setup just like yours but with type R's because I'm not a rich ****er. hah
What are composite speakers? Is that just another word for coaxial?
Yeah, I just found that out.
I'm not sure, I don't think I had the "upgraded" audio, or it was removed from before I got it. My X components were the ALPINE SPX-17REF, the older versions, so I paid just under $200 for them. Composite I was just confusing with coaxial...component and composite are cables so I attributed it to speakers unintentionally.
The question is, if you got front composites and mounted the two tweeters in a unique, non-stock location, did you not remove the two front monsoon tweeters?
Basically I'd go for two type r tweeters where yours are, 4 type r's in the front and back and get rid of those other two monsoon speakers
#20
I think the fronts are what matters.
