upgrade 2002 base
Old May 18, 2015 | 07:32 PM
speedemon's Avatar
Default upgrade 2002 base
Hi,
there are a few 98-02 SS Camaros being parted out in my area, and it seems like there are regularly. Besides the wheels and tires, what else would be a compatible upgrade for my base Camaro.
Thanks!
Old May 18, 2015 | 08:03 PM
Struts and sway bars. You could send the Struts out to be rebuilt. They may even have a life time warranty. The rear would be a posi. You want to be sure it has the same traction control connectors. if the rear came from a 6 speed car it would also have better gears. The V8 would have a tighter Rack and pinion.
Edit: the SS should have a aluminum drive shaft. You driveshaft has a center bearing and weighs like 40lbs. The aluminum one weighs like 5lbs.
Old May 18, 2015 | 08:10 PM
speedemon's Avatar
Excellent, thanks!
Old May 19, 2015 | 10:26 AM
torque_is_good's Avatar
the seats. Am I the only one here who has learned the hard way just how expensive are the interior pieces which are in good shape?
Old May 19, 2015 | 11:20 AM
speedemon's Avatar
lol, you are not!
Ashtray cover $30
factory floor mats $75
dash emblem $10
speaker cover $15
spare tire cover screws $15ea.
Fortunately, those items were missing, and the rest of my interior is pristine.
I am lucky, I live in the car capital of America, so there are always plenty of parts!
Take care!
Old May 19, 2015 | 05:35 PM
speedemon's Avatar
Also,
I just saw some SLP models parting out as well, anything additional from those?
Thanks!
Old May 19, 2015 | 06:43 PM
All SS's are SLP. SLP makes the SS.
I didn't mention hoods or rear decks, they tend to sell fast and not for cheap. Hoods can go for up to a $1000 I think the rear decks are $400-500
Old May 19, 2015 | 09:58 PM
J-Factor's Avatar
The one piece aluminum driveshaft will also improve torque at the rear wheels.
Old May 20, 2015 | 01:16 AM
clinebarger's Avatar
Your not serious, Are you?
Old May 20, 2015 | 10:22 AM
An aluminum driveshaft wouldn't be a "performance" upgrade at all, for his 2002 at least. The V6 models got a one-piece (steel) driveshaft around the 1999-2000 model year, no more two-piece. I had put an aluminum shaft on my old 96, and weighed both at the time. Steel one piece driveshaft: 16 lbs. Aluminum shaft: 12 lbs. 4 lbs. saved on a street car isn't worth the extra expense over a relatively inexpensive steel driveshaft.
