Tune Up Help
Old Jan 3, 2013 | 08:31 PM
RaiderGT's Avatar
Default Tune Up Help
Ok guys so I am going to be replacing the optispark and doing a tune-up this weekend. So far I have the following items:
-Opti
-MSD Cap and Rotor
-Summit Plug Wires
-Opti Harness
-Autolite Plugs
I should be getting a new water-pump tomorrow also. Is there anything else I should be getting or doing while I am in there? I read something on here about oil seals? Also I know i should loctite down the screws on the opti and put sealant on it. Where at exactly?
Old Jan 3, 2013 | 09:01 PM
would be a good time to replace the seals on the front cover. water pump drive seal, opti drive seal, crankshaft seal. there is a way to make a waterpump seal install tool from a marker cap. 69 made one up that worked great. https://camaroforums.com/forum/lt1-l...ve-seal-43601/
Old Jan 3, 2013 | 09:17 PM
RaiderGT's Avatar
Can I get those seals from my local autoparts store? I get steep discounts there and obviously if I am doing this this weekend They wouldn't ship here in time lol. And yeah I brought that up because I saw 69's marker cap guide.
Old Jan 3, 2013 | 09:30 PM
Buy the timing cover gasket set, all the seals, o-rings, etc. you need will be in there.
Old Jan 3, 2013 | 09:35 PM
RaiderGT's Avatar
Awsome thanks that's what I was looking for. Any advice on the whole Opti, take apart, reseal and loctite thing?
Old Jan 3, 2013 | 09:39 PM
Loctite the rotor screws, RTV where the cap mates to the body.
Make sure the tabs on the opti matches up to the drive hub, and ease the opti on by hand till it's set all the way back.
Do not "pull it on" by the mounting bolts.
Old Jan 3, 2013 | 09:46 PM
electrical grease on the connectors and plug wire ends. why autolites?
Old Jan 3, 2013 | 09:47 PM
RaiderGT's Avatar
Thats a big 10-4. I seriously don't know what I would do without this forum and you guys sometimes.
Old Jan 3, 2013 | 09:49 PM
RaiderGT's Avatar
Roger that. Autolites because when I was doing my order on summit they only had (3) of the plugs that I wanted in stock. Seeing as Ive used Autolites in pretty much everything else I just went with them as the alternative. Mistake?
Old Jan 3, 2013 | 10:10 PM
And, you're gonna swear it is, but the lower pulley is not pressed onto the hub. You can rap it off from the back side using a block of wood and hammer, alternating from side to side. When the rust and crud is cleaned off the mating surfaces of the hub and pulley, the pulley will slide right back on with ease. Also pay attention to the line-up arrow on the hub and line on the pulley.
