tubular control arms worth it?
Old Apr 4, 2014 | 02:43 PM
v64thgen's Avatar
Default tubular control arms worth it?
I have heard that on older cars they make a huge difference by making the front suspension geometry more modern, but what about on my 94 camaro? I would assume the geometry is pretty good so would tubular arms make much of a difference over new stock stamped arms?
Old Apr 4, 2014 | 05:09 PM
libertyforall1776's Avatar
Nope, if you want to do an upgrade, swap out the stock unit bushings with Moog ones which are the same as what the 1LE ones were. This has been well-fleshed out on LS1Tech, and if you are looking for suspension improvements, call suspension guru Sam Strano <http://www.stranoparts.com> and also ask this question, and talk about what it is you want to improve about the handling of your car.
The best bang for your buck are Bilstein or Koni shocks all around, then upgrade both sways -- the SS/WS6 ones or even better Strano's hollow sways.
Old Apr 7, 2014 | 10:27 AM
v64thgen's Avatar
Thats what I thought. I'll probaby buy a set of stock replacements with upgraded bushings. Thanks for the input.
Old Apr 7, 2014 | 02:04 PM
Cheeks's Avatar
August 2011 ROTM
Weight savings is the only advantange to the tubular arms, I have the uppers/lowers on mine to get weight off the front end
Old Apr 7, 2014 | 03:32 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I'm pretty sure the stamped arms weigh less than tubular, but the tubular ones give me a lot more fine adjustment so I can dial in my alignment, and set the camber and such properly if I go out for a track day.
Old Apr 8, 2014 | 04:03 PM
v64thgen's Avatar
well after doing a quick search it seems there arent even that many places that sell the stamped arms, the only place i saw that sells it is a place called mevotech. never heard of them, and they only have the uppers. looks like when i get around to it i'll be going tubular for uppers and lowers because im not going to be doing it myself and the price difference for labor between replacing the arms and just doing the bushings is probably similar. besides i do see a track day or two in my future once new parts start getting installed
Scott Johnson
Dec 11, 2012 07:28 AM
mrcamaro68
Aug 24, 2010 06:54 PM
1lowryd
Mar 17, 2009 06:45 PM
