trying for 400 whp
i presume it got changed for gears, plus changing shift point is part throttle only. at WOT both a speed and rpm threshold must be met. If you changed your gears and not the WOT threshold then it wont change. I have EFIlive and there is the option when you change gear ratio to set all shift points related to new ratio, it not you have to do it all manually. I have no idea if you still need maf plugged in as it is linked to auto changes too, dont know how, just what i've heard
