AC Problem
Old Apr 28, 2010 | 09:29 PM
masonhoban's Avatar
Default AC Problem
a few months ago it started to only blow cool (not cold) air when you werent moving, now it just blows hot the freon is new and full but still isnt working. any suggestions?
Old Apr 28, 2010 | 09:41 PM
have the car scanned should give an idea were to look.
Old Apr 28, 2010 | 10:52 PM
masonhoban's Avatar
it was scanned a few weeks ago and no code came up
Old Apr 28, 2010 | 11:05 PM
well then i would think its in the controls. does it get hot when u turn it up?
Old Apr 29, 2010 | 12:26 AM
RFxCamaro's Avatar
freon leak is my guess
Old Apr 29, 2010 | 01:55 AM
masonhoban's Avatar
no it blows the same temp no matter how high i crank it
Old Apr 29, 2010 | 10:09 AM
yep im gona say its in the temp switch. check the fuses and then pull the switch and test to see if its getting juice and putting out juice.
Old Apr 29, 2010 | 12:51 PM
MTRIMBOLI's Avatar
The air all of assuden stoped blowing through the vents inside, but blows at the feet. Any ideas?
Old Apr 29, 2010 | 05:40 PM
RFxCamaro's Avatar
then yupp there is a leak somewhere, trace vacuum lines to find it and try changing check valvle
Old Apr 29, 2010 | 05:54 PM
masonhoban's Avatar
same with me, is yours blowing hot too?
