Transmission Problem? I think.
Old Aug 22, 2009 | 10:36 PM
GoofieJ21's Avatar
Default Transmission Problem? I think.
I have a 99 V6 5spd manual. The description of the problems: Started happening all at once, it hasn't gotten any worse, it has stayed the same in the last couple of days. My fifth and reverse are having trouble going in gear. All other gears go in just fine but when shifting from 4th to 5th it sometime doesn't go in at all and I have to reapply the clutch once or even twice before it grinds into gear. Reverse its hit or miss because it will either go in fine one time and then it feels like something is blocking the gear the next. But when it does go into reverse it doesn't grind at all. I did just have my clutch replaced about 6 months ago so I've been told that it could be a pressure plate problem. But I have no idea. Does this sound like a clutch pressure plate or is my transmission going out? Thanks for the help guys.
Old Aug 23, 2009 | 11:19 AM
could be a linkage adjustment problem. otherwise i would say the syncro gears are going.
Eddie Cotter
Oct 11, 2014 09:43 AM
BoricuaHec01
Oct 30, 2010 01:09 PM
aktham
LS Series Tech
May 5, 2009 01:40 PM
harvick boy
82-92 V6 Tech
May 21, 2007 08:03 PM
SomeCallMeFonzi
Dec 14, 2006 04:41 AM
