transmission help
I have the biggest B&M I can fit on my car
Did you do it yourself? can you check your pressures? If a seal is not sealing 100% it will burn up the clutch pack pretty quick. It should show up on a pressure test.
OK thanks. No I didn't rebuild it myself but I put the motor and trans into my car myself And the bad part is the guy who rebuilt it past away 2 months after rebuilding it so iI'm just going to get it rebuilt then buy the biggest cooler
dsinclair999
Feb 21, 2011 11:24 AM
