trans 2 - 3 shift
Old Nov 22, 2010 | 03:07 AM
maudyZ28's Avatar
Default trans 2 - 3 shift
right, i've read common problems sticky and only thing it says if no 31. which is related, 2-3 sluggish above part throttle -> trans on way out -> rebuild.
The problem is that, say i've been driving about 20 mins but no WOT etc, but then open it up and have a good 1->2 shift, then it goes 2->3 but box hessitates like mad, just doesn't shift and hands, slips??
basically doesent engage gear imidiately.
Anyways say I do the same thing like 5 mins later and 2->3 is nice as solid as it should be. Why would this occur randomly, it dosent always do this ?? Could it be the shift solinoid B or something? any ideas?? sureley if it is trans on way out it would be a consitent degridation
Its an auto btw
thanks
Old Nov 22, 2010 | 06:16 AM
H2C's Avatar
H2C
Sounds like some kind of computer-engine-tranny link isnt reading something right.. did it only act up when your check engine was on or anything?
Old Nov 23, 2010 | 02:52 AM
maudyZ28's Avatar
nope, all pcm is ok etc (have efikive and checkk all links, codes), just does it randomly, no codes etc
just wondering if anyone else had same issue. Its only usually on the first WOT shift 2->3 of the drive, lie it just forgets that it has to shift or indeed does slip. but then its fine after that?
Old Nov 23, 2010 | 10:52 AM
are you getting a 1870 code? could be in the valve body.
Old Nov 24, 2010 | 02:59 AM
maudyZ28's Avatar
nope no codes, thats why its strange, like i said i have EFIlive and can check everything and the relavant codes and meanings but there is nothing on the pcm?
Old Nov 25, 2010 | 11:33 PM
VALHAR's Avatar
Check your TPS.
The TPS replaces the TV cable used on older trans. witch replaced the vacuum modulator.
Old Nov 26, 2010 | 02:45 AM
maudyZ28's Avatar
Originally Posted by VALHAR
Check your TPS.
So i assume that your saying my TPS might be sticking? It seems fine in the logs but ill got for a drive at some point and open it up and see if it does stick. might be in a while though, its snowy and icy over here
Old Nov 26, 2010 | 02:31 PM
VALHAR's Avatar
Also the TPS will ware down, being made of plastic and being turned by a metal throttle shaft. Plus a lose connection will cause a problem.
Chevra
Mar 29, 2012 08:41 PM
LetsRockZ28
82-92 V8 Tech
May 25, 2010 05:54 PM
Z28 Kid
Mar 19, 2008 08:04 AM
th3po1son
Jan 20, 2008 08:56 PM
sewerrat
Jul 13, 2005 05:46 AM
