Tranny swap?
Old Jan 29, 2019 | 01:03 AM
Jays's Avatar
Default Tranny swap?
So I’ve been posting here a lot since I got my Camaro... does anyone have a step by step guide on dropping out/installing the tranny on these? The only video I found was terribly shot and I couldn’t tell what bolts they were or weren’t taking out. Any help would be appreciated, cause I don’t want to have to take it to a mechanic (except for a rebuild of the trans itself)
Old Jan 29, 2019 | 07:17 AM
I used a factory service manual. is what year, what engine, auto or manual?
Old Jan 29, 2019 | 07:18 AM
I used a factory service manual. what year, what engine, auto or manual trans?
Old Jan 29, 2019 | 11:58 AM
Jays's Avatar
It’s a 96 with the 3800. Auto
Old Jan 29, 2019 | 12:57 PM
I do not have a step by step but I can give you 2 tips. Common mistake by beginners.
When reinstalling the trans make 100% sure the torque converter is seated. Check youtube for the process. If it is not seated and you start your car you will destroy the front pump and it can send seal cutting metal chips all through the trans. This new damage will most likely be more expensive then the original rebuild.
Get a long 3/8" extension, 30" min. Loosen the bolts between the engine a trans after you have removed trans cross member and slightly lower the back of the trans until you have line of sight on the bolts
Good Luck.
Old Jan 30, 2019 | 05:35 AM
this is for the lt1 trans but much of it would be same. https://camaroforums.com/forum/93-02...mission-52327/
John4649
Dec 16, 2012 01:49 AM
H3llboy676
25
Mar 9, 2012 12:59 PM
vXIcetreyXv
May 11, 2011 09:38 PM
camarowner
Aug 11, 2008 12:30 AM
littleredcar
Apr 7, 2008 12:09 PM
