tranny problems
Old Feb 9, 2008 | 09:05 PM
thadd154's Avatar
Default tranny problems
I am trying to change my clutchin my 95 Z28(T56). I have everything disconected(the tranny from the motor and the gear box from the bell housing). I've done everything short from using a comalong. Any suggestions?
Old Feb 9, 2008 | 09:24 PM
02StanGT's Avatar
Default RE: tranny problems
I don't understand the question... You can't get the clutch off or what?
Old Feb 9, 2008 | 09:38 PM
thadd154's Avatar
i can only get the tranny to slide back about an inch or 2. it's like it is hung up on something.
Old Feb 10, 2008 | 09:31 AM
02StanGT's Avatar
Driveshaft or tranny mount?
Old Feb 10, 2008 | 10:40 AM
thadd154's Avatar
everything is off tranny cross member bell housing drive shaft nothing in the way gear box dis connected from the bell housing it should just slide right off the input shaft but it won't.
Old Feb 10, 2008 | 03:02 PM
deltav's Avatar
Did you unhook the shift fork? Ifeverything is unhooked from the tranny, you should be able to see it the shift fork inside on the bottom left hand side (at about 8 O'clock position). Just press on the bowl-shaped semi-hole thing (for lack of the correct term) and pull or press down away from the tranny. It should snap right off with a little effort. Do this when the tranny is all the way in. Actually, Iunhook the fork beforeloosening any tranny bolts.
Jakobzara
May 9, 2008 12:29 AM
6v49der
Feb 21, 2008 01:20 AM
hurley870
Jan 28, 2007 11:55 AM
scottish_camaro
Nov 19, 2006 03:29 PM
Bubonic
Sep 1, 2006 10:10 PM
