Torque Converter
Old Apr 12, 2011 | 09:38 PM
NorthernCrew454's Avatar
Default Torque Converter
IM looking to get a 2500 stall torque converter. any recommendations? Im pretty sure i have a 4L60E Auto , confirm?? i found this on summit, would it fit? Putting out around 500 HP to the flywheel.
Hughes Performance 22-25 - Hughes Performance Street Master Torque Converters - Overview - SummitRacing.com
Old Apr 13, 2011 | 07:07 AM
Phalen123's Avatar
From what I've heard and with that power I think your gonna want more like 3000
Old Apr 13, 2011 | 11:00 AM
that is not a lockup converter. if you drive on the highway you will most certainly want a converter that will lock up. have a look here and see if you can afford. im using the #5x Torque Converter Diesel Torque Converters 68RFE Billet Low Stall
Old Apr 13, 2011 | 04:22 PM
what input spline count? 27 or 30
Old Apr 13, 2011 | 09:54 PM
what yr car? should be 30. i called and made sure they knew what i had so there would be not mix up on my part.
Old Apr 13, 2011 | 10:42 PM
1994 z28
Old Apr 13, 2011 | 11:42 PM
yep 30. what else has been done to the trany?
Old Apr 14, 2011 | 09:46 AM
Its completely stock right now, im in the middle of the engine rebuild right now. what do you recommend?
Old Apr 14, 2011 | 11:30 AM
i went with the level 3. i would think you would want to upgrade the servo's and sunshell/reaction shell at least.
jrgearhead
Jan 24, 2012 01:25 AM
tscw96
Dec 27, 2011 09:54 AM
freaky
Mar 13, 2010 12:28 PM
samtron
May 15, 2009 09:07 AM
microkid
Jan 15, 2007 06:25 PM
