Tire leak
Tire leak
I know this isn't a camaro specific question, but I thought I would get your opinions if you care to give them.
I had a screw in the tread of my new Hankook tire. None of the tire shops would patch it, as its too close to the edge (about 1" away). They say the patch won't hold. I put a plug in it but still have a slow leak. I do not want to buy a new tire. What about using slime inside the tire or do I need a new tire?
If anyone has any other suggestion let me know.
Thanks
http://www.slime.com/
Thanks
Am i the only one that ever put an inner tune into a brand new tire that couldn't be patched?
http://cgi.ebay.com/ebaymotors/17-IN...spagenameZWDVW
Can't say I've ever heard of anybody do that before. How's it handle?
i had tubes in my celica all 4 rims were bent and the car was a 91 with 380k miles and i got it for 100$ i wasnt gunna spend the money for new rims and while driving i couldnt tell the difference
Use the bigger plug and it might just seal completely. Going to be a pain in the ***** to get it in. Just ream it out well, make sure it's clean, then put the larger plug in. Should hold. Just keep in mind, they do last a long time, but eventually they will start to wear out and start to leak again.
if your buddy at the garage has a tube kicking around that fits then shove it in. it will work.
We're talking about Hankook tires which are one of the cheapest out there. He'll be needing new tires in 7k-10k miles anyway.
So, should they be categorized as the Yugo of tires?
But at $400 total cost to shoe the entire car I had to give them a try.
