Think i screwed through fuel tank..
Old Aug 12, 2012 | 03:15 PM
lets see a picture of the amp mounted, it may be your in a spot where the tank is not close.
Old Aug 12, 2012 | 03:24 PM
Jim in Indy's Avatar
Pull out each of the amp screws, one at a time & 'probe' with a long piece of coat hanger or equiv to see if you did nail the tank.
If you did, a sheetmetal screw with a flat washer, coated with Permetex #2 works like a champ for fixing oops like that. (I've traveled the ALCAN a couple of times!),
It's important that there be no hole at the top of the tank where vapor can escape uncontrolled. This fuel system always has a slight bit of positive pressure in it, and vapor is what burns....
Old Aug 12, 2012 | 03:55 PM
MKCoconuts's Avatar
Actually, gas liquid burns. Gas vapor explodes...
But to the OP, don't worry about it exploding. Just don't make any sparks or flames IF it's leaking vapor.
Old Aug 12, 2012 | 05:13 PM
wildcat123's Avatar
I went through the holes with a paper clip, only in one hole is it deep enough that it will fit the whole clip in, the rest im hitting the top of the tank with, and will bend the clip.
heres a pic:
top right one
About sealing it up, what exactly is a sheet metal screw?
Here is the one i used to drill the hole:
Another question, when sealing this up, should i use a long enough screw that will screw into the gas tank itself and fill the hole in it, or use a small one just to plug up the hole in the red hump metal? Will a screw sticking into the gas tank hurt anything?
Old Aug 12, 2012 | 06:16 PM
Greg08's Avatar
O man, thats hella close to where the front of the tank drops off, u may be ok.
Old Aug 12, 2012 | 06:20 PM
Greg08's Avatar
SEaling the red hump is just going to stop any fumes Coming in the cockpit
Old Aug 12, 2012 | 06:25 PM
The last thing you want to put in your tank is another screw. The screw will rust. Once you get rust in your fuel system you pretty much have to replace everything all the way to the fuel injectors.
Don't use RTV sealer it is NOT rated to work with Gas and it is not rated to work in a pressure/vacuum without a gasket to support it. Just about every parts store carries fuel tank repair kits. They are two part epoxy and they are stronger then the metal tank itself. As far apart as those holes are you should really think about removing the tank or figure a way to cut small access hole about 1" in diameter right over each hole that needs repairs. Maybe a metal cutting hole saw with a hose clamp on it to make sure you do not cut into the tanks.
FYI liquid gas will not burn, only the vapors burn. They explode when they are confind in a small area and can not expand.
Old Aug 12, 2012 | 10:11 PM
looks like the ones toward the front of the car are clear of the tank.
Old Aug 12, 2012 | 10:24 PM
Then what's below those holes that he's hitting and bending the paper clip with? The tank is under those holes, and you might just be missing the hole with the clip. Doesn't really matter how many hit or missed though, you know at least one went through, and that means fixing the tank. Lowering the tank down is the right way to fix it at this point, and to be sure there really aren't any more holes. Notice I said "lower". You won't have to remove the tank completely to gain access to the top to fix it.
Old Aug 12, 2012 | 10:32 PM
  #20
pressure test the tank.
