Are there benefits from larger injectors?
Old Apr 7, 2011 | 02:26 AM
Bandit 43's Avatar
Default Are there benefits from larger injectors?
I wanted to know if there are gains to larger injectors? If so what are they and what size would you recommend for the 3.8L?
Old Apr 7, 2011 | 05:05 AM
Injectors themselfs will not add any HP unless you have modded you motor beyond the the max HP of your origianl injectors can handle. Unless you are hitting 280+ HP your stock injectors are fine.
Old Apr 7, 2011 | 09:42 AM
you can lose power if the injectors are not flowing correctly. not a bad idea to have them cleaned and flow tested once in a great while. say 50 or 60k miles.
Old Apr 7, 2011 | 10:11 AM
Bandit 43's Avatar
Cool, thanks guys.
roger1
82-92 V8 Tech
Aug 23, 2013 11:05 PM
Matt.Thomas
Sep 12, 2009 11:32 AM
ScottD
May 13, 2007 11:04 AM
