swapping trans, 94z and 96z???
Old Aug 5, 2008 | 10:36 PM
evilbeef54's Avatar
Default swapping trans, 94z and 96z???
So im looking at picking up a 96z28 with some engine work done to it, it has a stock trans, the trans on my 94 z28 has some work done to it and is fairly fresh. Can I just swap the transmissions from the 1994 and the 1996 (mind you i am working with a floor jack and jack stands, not a lift or anything, andthey are both autos. I know from experience that i can swap 4 speeds in my 1972 camaro in about 30 minutes, im guessing that this will be a bit more difficult, true? Also wondering abouthow much the auto trans in these cars weighs, i know my m22 is nice and light
Old Aug 5, 2008 | 10:49 PM
usarmyrangrs's Avatar
Default RE: swapping trans, 94z and 96z???
The 4L60E is a tad hefty but can be muscled around. It's a little more complicated, making sure all of the connectors, cables, and plugs are all disconnected and reconnected as they're supposed to be. Torque converter bolts might not be the most fun of all things, especially if you're attempting this under the car. It's possible, however. Good luck with it.
But yes, as far as your original question, those transmissions are identical.
Old Aug 5, 2008 | 10:58 PM
evilbeef54's Avatar
okay, sort of what i wanted to hear, lol,i dont mind getting dirty as long as i dont crush my face with a trans
Old Aug 5, 2008 | 11:03 PM
Just be careful. Make sure everything is supported. As I said, the transmission is hefty but managable.
Old Aug 6, 2008 | 11:40 PM
95slvrZ28's Avatar
I would get ahold of a transmission jack so you don't crush yourself on accident. $50 for a cheap tranny jack seems a helluva lot cheaper than face crushing would be...
Old Aug 8, 2008 | 02:28 AM
evilbeef54's Avatar
ORIGINAL: 95slvrZ28
good idea, lol, how much clearance will i need for this, will it work with just a floor jack and jack stands?
Old Aug 8, 2008 | 05:29 PM
95slvrZ28's Avatar
It's not going to be easy without a lift, but it will be doable. The tranny isn't that tall, but I'm sure you'll run into some interesting stumbling blocks
Old Aug 11, 2008 | 06:25 PM
noz's Avatar
noz
good luck man sounds stuff without lifting the car those trans are heavy......
shaione
Jul 31, 2012 07:28 PM
cmcz450
Aug 1, 2010 09:29 PM
ccamaro88
Jan 4, 2010 12:06 AM
Mesosneaky
82-92 V8 Tech
13
Jul 11, 2009 07:47 PM
jgeis
Mar 13, 2009 05:49 PM
