suggestions??
Old Dec 2, 2007 | 10:02 AM
1994z28's Avatar
Default suggestions??
Im still having problems with my starter/flywheel. My last starter housing cracked in half and went to hell so i put a new oneon and it still grinds. sometimes it might turn over a couple of times and sometimes it might just hit and grind... I have spun the flywheel around and looked at all the teeth.. some look better than others but none look too bad to have problems. I looked for cracks and stuff but see none. I checked the torque converter toflywheel bolts and they were tight.There is a little buring i feel on the edge on the motor side of the flywheel.The mesh between the startergear and flywheel is good. For the heck of it i shimmed it in .020" and out .020" and have the same problem both times.
Do you guys think it is a good idea to get a smallfile and go between all of the teeth, maybe some of them are slightly rolled or something??
voxeltoxin
70-81 Transmission & Differential
Jul 24, 2012 09:48 AM
JoeA84
Mar 7, 2012 08:09 PM
Z28 M4N
Sep 24, 2007 04:50 AM
ninety3chevyz
Sep 6, 2007 07:16 PM
Morthose
Apr 10, 2007 02:29 AM
