subwoofer questions
I have the same speaker, but they are the three-way. They sound great. Are you going to be running an amp to them? If not they will be just fine, but if you are running an amp to them make sure they will be able to keep up.
Well you have to run an amp for the subwoofer or the speaker is useless. haha. Having the normal speakers run through an amp will help with your sound clarity and if the amp has a crossover then you can run the speaker and tweeter independently and get even better sound quality.
so how can i check if the 2way speaker will be able to keep up with my subwoofer and sub amp? or should i not connect the 2 and just keep it compnent in front coax in the back and Sub in truck with amp?
Ok. Here is the deal. haha. Get one single channel or two channel bridgeable amp with your subwoofer and then another separate four way amp for your normal speakers. If you want to keep it simple and get good sound then go with two or three way speakers. These speakers are just ones that have smaller speakers build in that work as tweeters.
How much do you want to spend, how big of a sub do you want, and what sound quality are you looking for?
wait.....you want to spend $120 on new speakers, subs, and an enclosure? Are you not getting an amp. Have you looked at how much speakers and a sub are? Are you planning on just throwing a normal square enclosure in the back of your camaro? A decent small amp will cost you about $150. It is sounding like you need some serious direction in this area. Why don't you pm me with your email and we can talk about exactly what you need to get.
