stumble on gas when warm
Old Dec 13, 2012 | 11:53 AM
Trio3b's Avatar
Default [solved]
Looks like after replacing some of these parts, the stumble is better described as a misfire under load when warm which points us back to ignition, low fuel pressure or manifold leak. After ruling out FP and vacuum leak, concentrated on ignition.
Figured out it was a new set of Duralast wires that were bad. Replaced with set of AC-Delco and all seems fine now for the past day or two. Will run it a few more days and post back.
I have used Duralast in the past with no problems. Maybe this was a bad batch. They were routed properly with standoffs. The AC-Delcos are the correct set according to part # but too short and had to route them up against block and exhaust manifold. We'll see how long they last but as of now no misfire.
1993_Z28
Feb 8, 2012 05:01 PM
backinac
Aug 13, 2011 11:21 PM
max1995
Nov 12, 2008 01:10 PM
max1995
Oct 24, 2008 10:57 PM
blue94z28
Jun 22, 2005 10:35 PM
