stuck throttle?
Old 03-31-2013 | 09:09 AM
Chaotic94's Avatar
September 2011 ROTM
Here ya go. Sorry about the bad quality. Pulled over on the side of the highway and snapped a pic with my cell phone. I tightened my zip tie pretty tight. Never ha an issue with it popping off since then. Good luck!
  #32
Old 03-31-2013 | 09:44 AM
Dana's Avatar
I'm not thinking that's the one that was off on mine. That's the one that used to pop off. I wish I were home so I could see mine lol.
  #33
Old 03-31-2013 | 09:53 AM
Dana's Avatar
My pop sound is like a cork out of a wine bottle but yeah like a balloon too and the hose (I'm thinking) is near there but to the left. I can't tell from your pic because it's not zoomed out. Maybe I can see mine on a photobucket pic. Got slow internet service here!
  #34
Old 03-31-2013 | 09:57 AM
Chaotic94's Avatar
September 2011 ROTM
Well any of them at pop off, you can put a zip tie around to prevent from coming off. Same idea tho.
  #35
Old 03-31-2013 | 10:01 AM
Chaotic94's Avatar
September 2011 ROTM
Here's a better picture for you:
  #36
Old 03-31-2013 | 10:17 AM
Dana's Avatar
Would symptoms be the same though? Excessive RPMs and seem like throttle is stuck? If u look at the part u tied off, go to the left of that connector where a small hose goes in, that's where mine popped off. My husband said he has the one you tied off, clamped closed already.
  #37
Old 03-31-2013 | 10:20 AM
Chaotic94's Avatar
September 2011 ROTM
Yes the symptoms would be the same. High idle and a whistling noise probably. Just clamp it off like you did the last one and you should be set to go.
  #38
Old 03-31-2013 | 10:22 AM
Dana's Avatar
Ok. We'll be home tomorrow. I'll let u know. Thanks!
  #39
Old 03-31-2013 | 12:15 PM
chaotic have you ever checked the gas tank relief valve. it sure sounds like that may be the issue. thanks for posting up the picture.
  #40
Old 03-31-2013 | 10:40 PM
Intake should never see pressure, no less enough pressure to push or a hose unless the hose is just a worn out. Infact that much pressure could damage a vacuum gage. Even the ones design to read pressure are only good to 10 psi.
I am very curious as to what could pressurised an entire intake enough to blow a line off, Even cars that had bent intake valves that would push the entire content of the cylinder into the intake will not blow off a vacuum line unless it backfires. There is always one cylinder on the intake stroke so what every is poping the hose off would need a massive amount of air Very quickly. We are taking turbo charger levels of volume unless I am thinking of this wrong.
Quick Reply: stuck throttle?
