Stubborn Shifter Cup Bushing
Old Feb 7, 2018 | 07:05 PM
ahaas2011's Avatar
Default Stubborn Shifter Cup Bushing
Having some trouble getting out the shifter cup bushing. Don’t know if it’s frozen or anything, it’s below freezing where i live, but i’ve tried heating it up and gettinf it out but the only thing that has happened is a broken top part of the bushing. does anybody know how to really get this thing out?
Old Feb 7, 2018 | 08:27 PM
looks like its glued in place. plastic as well. drilling out may be the only way. looked here https://www.scribd.com/document/1719...Service-Manual i see hawks has brass ones, Tremec/Borg Warner T56 T5 Bronze Shifter Isolator Cup Bushing - Hawks Third Generation
Old Feb 8, 2018 | 07:57 AM
ahaas2011's Avatar
thanks so much man. where should I drill at though? I’ve tried a screwdriver and hammer as well as a small saw along the edge before posting this, i’m seeing no progress so i’m not sure if this will work. I bought an oem bushing because i don’t really trust the bronze ones, should i glue that one in or just put it in and leave it?
Old Feb 8, 2018 | 09:13 AM
yah drilling could be troublesom, might try heating it again, cant believe it hasnt broken up. do you have a good heat gun, get it hot enough an it should soften the plastic up.
Old Feb 8, 2018 | 09:17 AM
says to use adhesive so it must need to be stable. sounds like someone used some good glue before
Old Feb 8, 2018 | 10:55 AM
ahaas2011's Avatar
right lol. i don’t have a heat gun to use but do you think a really thick drill bit that fills up the entire hole would get it out?
Old Feb 8, 2018 | 03:30 PM
that was my first thought but i have gotten myself into trouble drilling stuff so thought maybe not,,, lol.
ahaas2011
Feb 7, 2018 07:04 PM
chevcamaro
Dec 5, 2011 12:06 PM
9434V6
Sep 11, 2011 01:35 PM
EggboaT
Sep 13, 2007 06:37 PM
Conundrum
Mar 29, 2007 08:33 AM
