Strange Camaro problem need insigt
Old Sep 17, 2015 | 12:50 AM
Indygirl98's Avatar
Default Strange Camaro problem need insigt
So I almost hit an animal in the road tonight. I pulled left hard so avoid the animal and somehow blew the fuel pump fuse. The check gauges light came on and I lost all power to the car. The car has a recently new fuel pump, fuel pump assembly, and fuel relay. I replaced the blown fuse, and I still can't get the car to start! It was in full working order when This near accident happened. Is there something I'm missing as to why it will not start? I have a 1998 3.8L
Last edited by Indygirl98; Sep 17, 2015 at 01:03 AM. Reason: Adding year and type car
Old Sep 17, 2015 | 09:04 AM
95z28man's Avatar
When you turn the key to "on" can you hear the fuel pump kick on any? Are you able to check if you have fuel pressure?
Old Sep 17, 2015 | 01:35 PM
95 camaro 406's Avatar
wow thats strange i never heard of that one ,does in like said above the fuel pump kick in or on when turn they key ,have the person who put the pump in look at it ,is all i can think of ,or wait for another to chime in,thats a tough one ,could be one of the bigger relays are loose. e
Old Sep 17, 2015 | 03:24 PM
Indygirl98's Avatar
Well, mystery solved. I called mechanic today and he asked how much gas was in it, I was down to a little less than a quarter of a tank. He told me to exchange the horn and fuel pump relay. It fired right up! I guess maybe I sucked air in the pump when I did that spin out. Im back on the road! I'm so happy you guys replied and tried to help! Thank you!
Old Sep 17, 2015 | 06:35 PM
Default well cool
yes they can run out at about an 1/8th.glad it worked out
buddy_holly
Apr 5, 2011 02:39 PM
redreffitt
Mar 20, 2011 09:52 AM
warehimer33
Dec 1, 2010 04:30 PM
eric_m96
Jun 19, 2006 01:09 PM
MrTasty95
Jun 6, 2006 09:51 PM
