Still problems
well i finally got my 94 z28to run after a new opti install. It will fire right up on the first try when cold and run fine but as it heats up, it gets harder and harder to start after i turn it off. It will get to the point where it wont start at all but will sound like it is trying, it sounds almost like run-on or something but while i am trying to start it rather than turning it off. But the car will run fine until i turn it off. When i try to restart is when I have problems. I can wait a few minutes(3-4min) and try it and it will usually start. I know the plug wires are routed correctly, i found no vacuum leaksand i have no codes.I replaced the plug that comes from the main harness to the opti harness with a new 4 pin weather pack connector b/c i found that it wasnt making good connection, i could wiggle it and the car would die. I thought this was my problem but after i replaced it i still have the starting issue.
Anyone have experience with this type of problem? i will be thankfulfor any help you can give.
hey this is if u have headers.. ur headers will heat ur starter up and it will make it hard for it to work i had a 95 and it did this to me i went to napa and just bought thier best starter and it fixed my problem for starting...
