Steering Replacement
Old 07-09-2024, 11:13 AM
PHX LT1's Avatar
Well in my case, it probably wouldnt be a bad idea to change it since the motor and trans are still out of the car.
Old 07-09-2024, 11:19 AM
If I remember right the hose are more of a bear then the rack itself. 30 year old rack, Those outer seals may not have much longer. Also if the pump fails and sends metal through the rack that can cause issues. With all that room I would be tempted to add a filter to the high pressure side while it is all a part.
Old 07-09-2024, 11:27 AM
PHX LT1's Avatar
Probably not a bad idea. I'll be picking up the engine this week so I'll see where we'll go from there,
Old 07-09-2024, 01:16 PM
I was replacing my ps pump every few years. I added an oil cooler to my steering system haven't had and issue with the pump yet. been a over 5 years.
Old 07-09-2024, 04:26 PM
PHX LT1's Avatar
Where did you put the cooler at? 4 gens are not known for their spacious engine compartment.
Old 07-09-2024, 09:43 PM
under the radiator support behind the front air dam its not very big.
Old 07-09-2024, 10:41 PM
I have a trans fluid cooler in front of radiator or I would have put it there. make sure you're on the return line if you do it.
Old 07-10-2024, 01:19 PM
PHX LT1's Avatar
Thats bad ***! And thats for your ack and pinion?
Old 07-12-2024, 03:12 PM
yep power steering
  #20
Old 07-12-2024, 05:16 PM
PHX LT1's Avatar
I'm going to look into this once I get this car on the road. Still got a ways to go before I can even think about this, but you have given me some ideas.
Blackrag
07-26-2022 08:47 PM
phat69Camaro
04-17-2014 02:20 PM
idaho66stepside
05-02-2012 08:06 AM
galigntech
12-14-2008 08:41 PM
SpecterGT260
05-05-2008 08:04 PM
Quick Reply: Steering Replacement
