STEAM VENT CONNECTION QUESTION???
I have an LT1 out of a 95' camaro and i have it carbuated. I am not sure exactly how to hook up the hose for the steam vent tube that comes out from the heads to the front of the motor on the passanger side of the intake. I have looked on line to see if i could get some help there, but i am not able to see a clear pic on how i need to connect it. I thought it was similar to a throttle body bypass but i am confused on if i need to hook the hose up to the little hose coming off the upper radiator hose or connect it with a T-fitting to the heater hose that drops into the top of the water pump near the thermostat housing. if someone could shead a little light on this that would be great!
